查看: 6498|回复: 8
[CSR8系列] How to set pairing PIN to CSR8675
发表于 2019-11-13 19:09:39 | 显示全部楼层 |阅读模式
Hello,
I have a CSR8675 and I want to set a PIN for pairing device. I found that I need to change PSKEY_LOCAL_SUPPORTED_FEATURES at PSTool. Default value for it was feff fe8f ffdb 875b. People say I need to change it to ffff fe8f ff9b 8753. But when I do this CSR8675 not even start until I revert changes. Tell me please how can I set PIN code for pairing?
签到总天数:15天
签到总奖励:72金币
发表于 2019-11-14 14:18:18 | 显示全部楼层
CSR8675需要修改代码,你的方法不适用。
 楼主| 发表于 2019-11-14 15:44:40 | 显示全部楼层
Thanks for your answer. So I need to find a firmware which support PIN for pairing or PIN can be set only with source code?
签到总天数:15天
签到总奖励:72金币
发表于 2019-11-14 18:18:21 | 显示全部楼层
Fedot01 发表于 2019-11-14 07:44
Thanks for your answer. So I need to find a firmware which support PIN for pairing or PIN can be s ...
输入PIN码要在代码里面打开pin code功能才行。
 楼主| 发表于 2019-11-15 02:21:33 | 显示全部楼层
Could you tell  how can I do that?
签到总天数:15天
签到总奖励:72金币
发表于 2019-11-15 10:25:25 | 显示全部楼层
有源码吗? 没有源码改不了
签到总天数:767天
签到总奖励:6071金币
发表于 2019-11-15 15:43:32 | 显示全部楼层
在中国请将中文
 楼主| 发表于 2019-11-15 19:09:17 | 显示全部楼层
52bluetooth 发表于 2019-11-15 10:25
有源码吗? 没有源码改不了
I'm sorry. I have not the source code. Only a CSR8675 and a programmer FT232RL.
签到总天数:15天
签到总奖励:72金币
发表于 2019-11-16 10:27:21 | 显示全部楼层
那么你需求的功能就无法实现了,必须要源码。
GMT+8, 2024-11-23 16:06 , Processed in 0.998647 second(s), 24 queries , Gzip On, MemCached On.
